Nvidia and Linux help
Go to solution Solved by GuyNamedBrad,
Try this may or may not work in your scenario
1) create or open this conf file:
sudo nano /etc/modprobe.d/zz-nvidia-modeset.conf
2) add the following line:
options nvidia_drm modeset=1
3) update your initramfs
sudo update-initramfs -u
4) reboot
Side note: are you using proprietary driver from under the additional drivers under settings?
Alright im on Ubuntu budgie and i've been working on getting everything working correctly with my gpus and Linux. I am having screen tearing pretty commonly. This occurs with and without force composition pipeline and or force full composition pipeline. i've had this issue with gnome and budgie (idk if other wouldn't) and driver version is the most recent 440. I have a 1070ti and a 1050ti the issue occurs when regardless if only one is plugged in or both. I need both for work that I do. Do any of you use ubuntu and not have this issue? Do any of you use a different distro and not have this issue lmk. Any suggestions would be appreciated.
https://linustechtips.com/topic/1215527-nvidia-and-linux-help/
4) reboot
[DESKTOP] CPU: Intel Core i7 8700k GPU: ASUS ROG 2080TI RAM: 64GB Corsair Fury DDR4 Mobo: Asus z390-A Prime
Storage:1x 1TB Samsung 990 Pro SSD 2x 1TB WD Black SSD, 2x 3Tb Seagate  HDD PSU: Seasonic 950W
Monitors: 2x Asus TUF Gaming 24" 1440p  144hz, 2x LG  75Hz 1080p LED
[SERVER/NAS] CPU: Intel Core i7 7700K GPU: Nvidia 1060 6GB RAM: 32 GB Corsair Vengeance Mobo: Asus z-170P D3
Storage:1x 1TB Western Digital SSD, 4x Ironwolf Pro 12Tb HDD, 2x 2TB WD Blue  PSU: Thermaltake 650W
[LAPTOP (MacBook Pro 16")] CPU: 2.4 GHz 8-Core Intel Core i9, RAM: 32 GB 2667 MHz DDR4, SSD: 2 TB
GPU: AMD Radeon Pro 5500M 8GB Display: 16-inch (3072 x 1920)
https://linustechtips.com/topic/1215527-nvidia-and-linux-help/#findComment-13766847
14 minutes ago, sp331yi said:
Suggestion -- a different distro not utilizing a recource-hogging DE -- maybe eXtern OS
I like heavier distros simply because of support. I do a lot of work on my pc I need something with a lot of support but I also don't personally enjoy using Windows.
4) reboot
Honestly if its not fixed its miles better Thank you I think It's fixed.
https://linustechtips.com/topic/1215527-nvidia-and-linux-help/#findComment-13766893
Sounds good bud!
https://linustechtips.com/topic/1215527-nvidia-and-linux-help/#findComment-13766913
