Hello, I have this tubing run that leaks from both fittings on two events and I just re-set the tube and tightened it and it hasnt leaked yet but I was wondering is the turn it's doing to tight and can that possibility cause a leak? It's 10/16 tubbing using Barrow fittings
https://linustechtips.com/topic/1215156-thoughts-on-leak/
No that shouldn't be too tight of a turn, but a couple of 45° fittings couldn't hurt.
Did the O-rings look okay? Are the barbs fully inserted into the tubes?
I have had no issues with my 10/13 Barrow fittings.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13764216
That left run into the cpu doesn’t seem to be straight when it goes into the fitting.
Usually this can result in the tube not going all the way in.
possibly you are inserted part the way on one side and all the way on the other.
 You could put a straight piece into the fitting see how long the tube is when it’s all the way in then see how much tube the current one is in.
CPU | AMD Ryzen 7 7700X | GPU | ASUS TUF RTX3080 | PSU | Corsair RM850i | RAM 2x16GB X5 6000Mhz CL32 MOTHERBOARD | Asus TUF Gaming X670E-PLUS WIFI |
STORAGE
| 2x Samsung Evo 970 256GB NVME  | COOLING
| Hard Line Custom Loop O11XL Dynamic + EK Distro + EK Velocity  | MONITOR | Samsung G9 Neo
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13764268
What do you mean by straight piece? Also I believe this is the issue because when it leaks one part of the tubing is coming out of the fitting and is easily pulled out
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13764299
When the tube is completely flat it fits into the fitting all the way.
 Your tune bend appears to keep bending all the way into the fitting.
 See below you can do the bend just where the fitting goes in should be straight so all sides of the Oring are compressed evenly.
STORAGE
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13764378
So I should re do that tubing run to make it longer?
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13764407
This is a simple test you can do yourself to check for leaks, nobody here will be able to tell you by looking at the picture. Just do the simple classic Soapy bubble around the fittings air pressure test, you have a leak pressure tester right ?
Also, that looks like a Gigabyte X570 Aorus Extreme, that's a $1100 CDN motherboard.... I personally wouldn't be playing games with some weird soft tubing bends here, is PETG or Acrylic tubing not an option for someone who can afford a $1100 motherboard ?
The other thing is I wouldn't trust Corsair current gen blocks right now, look at that GPU block of theirs that was missing a third screw and was leaking, it's all over YouTube. No idea how R&D missed that, it was such an obvious problem, and it's the same guys making their CPU blocks I assume.
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13764520
Yes its an x570 xtreme. I did not do petg because i don't have a heat gun to bend it and stuff.
Yes i saw that but I did not hear anything wrong with there cpu blocks and the block so far has been leak free but the fittings have leaked 3 times now because the tubing pops out even though I got it as right as it will go
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13764583
No doubt about it the connector block could have been better designed but the whole leak risk thing is a total storm in a teacup, they only leak if you put entirely unrealistic vertical stress on them like aggressively pulling the tubing up or down.
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13764988
unrealistic?  did you see the video ?   Jay just lightly pulled it up and it started gushing, but if you're ok with that type of risk then you got some balls, props to you buddy.
Ok well, soft tubing, for example I just disassembled some soft tubing yesterday (Pump to Reservoir)  and on one of the connections the soft tube was angled out enough to where water could leak out. That was just from lightly moving and repositioning the units within the case when I was installing it, and everything was tight before.
You can get a Heat gun at any local hardware store, they start @ $20 and you only need a basic one + tubing $20 + silicone insert/cutter $10....
that's $50 of items right there that are easily available compared to the risk of leaking over your $1100 motherboard
good luck
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13766437
good luck
Hardline Turbing has a lower chance of leaking then soft tubing?
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13766474
Hardline tubing once you plug it into the fitting it won't really move unless you accidentally touch it or something, it will only fail or pop out if there is some sort of catastrophic failure, it takes more to make it fail basically.
Meanwhile soft tubing can casually flex and moves around on it's own sometimes, usually during the first little while of setting up a new loop when the pressures are all settling down and air being worked out, etc..  I mean that's literally what just happened to me today when I took it off after 2 weeks of running it.
But then at the same time some people will tell you that's exactly the reason soft tubing is safer, because it can "bend and flex" if needed not allowing the stress to get too much.   Not in my experience so far anyway, but I'm pretty new to this, just completed my first hard loop a month ago.
Honestly just looking at that picture, if I was you I would rethink the positioning of your components, that radiator is clearly too big to fit in that spot comfortably, it's pressing right up on the VRM heatsinks which isn't all that good.
It would give you more space to work with to make proper routes, but I mean you can make a hard tubing bend there on the left, you'd need 1 or 2 90 degree fittings probably unless you're excellent at bending hard tubes.
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13766513
Yes.
Jay applied direct force to the junction which is a situation which will never manifest itself in normal usage. I can count the times I've reached into my case and randomly tugged on things on the fingers of my left knee and I imagine most other people can too.
What risk? Name a single "typical" use case in which that junction will be subject to the movement shown in the videos.
I'd happily use the Corsair GPU blocks in my system with no fear of leaks because the scenarios in which they're shown to leak are so far removed from anything that a reasonable or rational person would be subjecting them to that they're totally irrelevant. Hence, storm in a teacup.
Also, FWIW soft tubing fixings are significantly more secure than hard tubing ones. The clamp pressure of compression fittings is much higher than dual o-ring hard line fittings, and angled soft tubing cuts are significantly less problematic in terms of getting a proper seal. Neither should present much of a leak risk to someone vaguely competent, but apparently people go round aggressively pulling on GPU block junctions for no damn reason so what do I know.
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13766566
Do you have another angle of that short tubing going into the IN port on the CPU block?
It seems like a somewhat aggressive bend from the radiator...slightly longer length tubing, to give it more slack, might help.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13766640
1 hour ago, HM-2 said:
Yes.
Well if you don't think it's an issue you're entitled to your opinion of course, but facts remain that it's clearly a design flaw, otherwise it wouldn't have been acknowledged by Corsair themselves, never mind the YouTube gurus.
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13766766
Yeah I'll eventually switch to hardline tubing. Also it's just the picture, in reality theres over half a inch of space before the radiator hits the vrm heatsink
https://linustechtips.com/topic/1215156-thoughts-on-leak/#findComment-13766874
