5 minutes ago, Stahlmann98 said:
What do you mean with hot-swappable?
Some keyboard have switches that can be hotswapped. AKA don't need to be soldered to the board.
@AlmondYum
How stuck are you on USB C. The only hotswap I can recommend isn't usb c but honestly blows my mind in value and quality.
https://www.pcgamingrace.com/products/gmmk-full-brown-switch
https://linustechtips.com/topic/1214227-little-help-please/#findComment-13756475
If you mean removing the keycaps while running, pretty much any mechanical keyboard can do that.
21 minutes ago, AlmondYum said:
I’m on the look for a 65% Hot Swappable High Profile Keyboard that has USB-C . If anyone knows any ones I can get or if yourself have one please let me know thanks :)
I can recommend the Corsair K63 Wireless. I use it myself and have zero complaints. It has everything you requested above. The only thing is, it comes with a Micro-USB. Why do you need USB-C specifically?
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1214227-little-help-please/#findComment-13756481
He's not talking about that, hes talking about switches, not keycaps, these old things that hide beneath the caps  HTB1JRqofaAoBKNjSZSyq6yHAVXaR.jpg
@AlmondYumhttps://drop.com/buy/drop-alt-high-profile-mechanical-keyboard
https://linustechtips.com/topic/1214227-little-help-please/#findComment-13756504
The Massdrop Alt has a high profile version, which is also available as a barebones kit. $190 for the barebones kit, $230 with switches and keycaps, or $380 with SA Laser keycaps. The Caps-Unlocked CU65 R2 is also going to happen at some point, if you're willling to wait for a bit.
Other than also not being 65%, not being hot swap, and barely high profile. And I'm guessing OP probably wants a somewhat decent keyboard with actually decent switches and keycaps
Edited by seon123
Something something
https://linustechtips.com/topic/1214227-little-help-please/#findComment-13756514
I would want usb c because I would travel with it more often ,
https://linustechtips.com/topic/1214227-little-help-please/#findComment-13756540
Actually I plan on putting in my own Switches , but I want to get a solid keyboard to begin with
https://linustechtips.com/topic/1214227-little-help-please/#findComment-13756545
