4 minutes ago, xyan3 said:
im buildimg a budget com for warzone with ryen 3 3300x and geforce gtx 1660 6 gb ventus xs oc
qn is what resolution setting should i run on to avoid bottlenecking
Run at whatever you like best. Turn down the graphics if you want high refresh. Turn them up if you like good visuals. Don't worry about bottlenecking- you only need to worry about that when you are buying, and a 3300x and 1660 is a very nice pairing
edit: read your question kinda wrong. Resolution, definitely go for 1080p
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
What ever you have
Tho the system is perfectly able to handle 1440 ( at lower graphical fidelity tho )
Edited by TofuHaroto
Phone: Pixel 3a (Purple-ish).
Build Log:
3300x wont bottleneck anyth ing under rx 5700 XT on 1080p so you are fine with all the settings. but your gpu might be the bottleneck so going to medium settings will minimize the bottleneck
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
3 minutes ago, xyan3 said:
im obviously v dumb in com knowledge thus this qn might sound stupid. if i get a 60hz monitor tht means my game cannot run at 100 right
it can run at 100fps but you wont see a difference between 60 and 100 fps.
Just now, xyan3 said:
so i should i only get a higher hz monitor when my fps is upgraded to 200
yes
