I am looking to buy new gaming pc and i was looking for these parts
Ryzen 5 2600
Msi Rx 5700 mech oc
MSI B450M-A Pro Max
16 gb ram
1 tb storage
I saw one review for that motherboard that 5700 xt wouldnt fit with bottom connectors. I am asking for hel to find out If 5700 normal version could fit. Thank you for your answers
I apologize for My grammar im not native speaker
https://linustechtips.com/topic/1213456-does-it-fit/
what? If the card uses PCIe, it will fit in every PCIe slot. If it doesnt, something's faulty.
But the problem is the board, just too weak for the CPU.
Desktop benching:
https://linustechtips.com/topic/1213456-does-it-fit/#findComment-13750823
Would The board Be okay If i changed it for ASUS TUF B450-PLUS Gaming?
https://linustechtips.com/topic/1213456-does-it-fit/#findComment-13751737
dont overclock and it will be fine
Desktop benching:
https://linustechtips.com/topic/1213456-does-it-fit/#findComment-13751742
Yes
If it has a x16 slot ( which it has )
You good
Edit : and that board is fine
Edited by TofuHaroto
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1213456-does-it-fit/#findComment-13751754
6 minutes ago, TofuHaroto said:
Yes
You good
I meant its mATX board The original one and below The x16 slot it has USB front panel and fan plugins so i was wondering if anyone had personal experience that 4.8 cm card would still leave space to Access these connectors?
https://linustechtips.com/topic/1213456-does-it-fit/#findComment-13751767
The USB port is at the bottom and so is the pwm headers
Either way it will fit
Build Log:
https://linustechtips.com/topic/1213456-does-it-fit/#findComment-13751771
3 minutes ago, Isaclaihorinne said:
The other guy Said it is not powerfull enough?
Jurrunio said it is
It's just not good for overclocking
Build Log:
https://linustechtips.com/topic/1213456-does-it-fit/#findComment-13751782
