Is GTX 1650 Advanced edition 4GB GDDR5 worth it ?
guryu
my gpu died after 7 yrs. and i'm looking for a budget gpu that would work for normal gaming .
No unless you can find it much cheaper than usual. It's no faster than an RX 570 for example.
At the very least, get the GDDR6 edition. Preferably, 1650 Super.if PCIe 6pin plug is fine.
Desktop benching:
No
The 1650 is only worth it if you don't have a pcie connector
If you do get a 570 and if possible a 1650 super
Phone: Pixel 3a (Purple-ish).
Build Log:
Other options I have in mind are  ROG-STRIX-RX570-4G-GAMING and ROG-STRIX GTX1650-O4G
No
ROG-STRIX-RX570-4G
What about the 8gig model ?
If you can't get the one with the larger frame buffer, this one will do
Build Log:
5 minutes ago, TofuHaroto said:
No
I think this is a noob question but do I have to consider other apps when migrating to AMD gpu ? Thank you so much for your reply.  I really had a hard time choosing gpu this time of pandemic :(
Different drivers
No you won't
Build Log:
3 minutes ago, TofuHaroto said:
Different drivers
No you won't
Thank you so much for your time. I really appreciate it.
