I did an oopsie.
I bought a new desk recently and I was setting it up and unplugging my pc and stuff , and I unplugged all the stuff and trying to put it on the new desk.
I put away the monitor and the psu power cables together i didn't know they would look identical ,
So I can't figure out which one is which they are literally the same connectors...Like which one goes to the psu and which one goes to the monitor?
I have a corsair Tx650m and an AOC monitor.
any ideas ? it says the same voltage and Amps on both connectors....
Edit: One says HONGPU on it and the other says EAC if that helps a bit
https://linustechtips.com/topic/1212305-power-cables/
1 minute ago, Bruh1 said:
I did an oopsie.
Check if the cables mention the same AWG.
If so, they are identical cables and it doesn't matter which you plug in where.
https://linustechtips.com/topic/1212305-power-cables/#findComment-13741896
