0rpm mode
It will start spinning after a certain temp
It's normal
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1211896-gpu-fan-not-spinning/#findComment-13738986
A lot of aftermarket cards have a 0 rpm mode when the card is at idle.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/1211896-gpu-fan-not-spinning/#findComment-13738990
Just now, Flyingchickennugget27 said:
What is 0rpm (sorry im a noob so idk what that means)
Basically as it sounds, the fans do not spin until a certain temperature is reached.
زندگی از چراغ
https://linustechtips.com/topic/1211896-gpu-fan-not-spinning/#findComment-13739007
