i built my pc a few hours ago and have been trying to figure out how to fix this problem: the monitor says no signal when i plug in my displayport cable into it (also plugged into gpu) also ive noticed that when the monitor is turned on the gpu fans stop spinning, i plugged the pc into a mini tv and it worked fine even though the gpu fans stopped spinning, when i plugged my monitor into my bros laptop to see if it was the problem and it worked just fine, idk what to do plzzzzzz help
https://linustechtips.com/topic/1211885-plzzzz-help/
Check that you've got all the wiring inside the PC correct, check that the power for the GPU is plugged in. Other than that I don't know what to suggest rn
Desktop - i5-9600KF @4.8GHz all core, MSI Z390-A PRO, 2x8GB Corsair Vengeance 3000MHz, MSI GTX 1660S OC 6GB, WD Blue 500GB M.2 SSD, Seagate Barracuda 2TB 7200RPM HDD
Laptop - ASUS ZenBook 14 with ScreenPad, i7-1165G7, Xe iGPU 96EU, 16GB Octa-Channel 4200MHz, MX450 2GB, 512GB SSD with 32GB Optane
Old Laptop 1 - HP Pavilion 15, A10-9600P, R5 iGPU, 8GB, R8 M445DX, 2TB HDD
Old Laptop 2 - HP Pavilion 15 TouchSmart, i3-3217U, Intel HD 4000, 4GB, 1TB HDD
iPad 2018 - 128GB
iPhone XR - 128GB
https://linustechtips.com/topic/1211885-plzzzz-help/#findComment-13738902
yea yall stop the off topic and help the dude lmao
17 minutes ago, yaboistar said:
make a proper post title rather than this crap and then people will actually look at your problem rather than actively ignore your post to avoid getting brain damage.
18 minutes ago, Tan3l6 said:
Offtopic: your avatar is a mess.
Maybe it's ok in some dark theme, but with bright theme it's a mess.
https://linustechtips.com/topic/1211885-plzzzz-help/#findComment-13738926
Guest
