I recently got my hands on a gtx titan so I wanted to upgrade to that one from my gtx 1050ti.But whenever I put it on my motherboard it refuses to post on screen.I tried everything from the psu resitting the gpu checking the ram and resetting the cmos also updating to the latest bios version, but nothing worked. I tried the card on my brother's pc and it worked perfectly fine but when I tried his 5700xt on my pc it wouldn't post too. I believe that the pcie slot is faulty on my motherboard(note that the gtx 1050ti works perfectly fine and posts but the other cards don't even though they work on my brother's pc). If so what do you suggest on doing. Thank you very much for your help and time.
Specs include :
B450m ds3h motherboard
Gtx 1050ti oc windforce gpu
16gb ddr4 2400mhz
Ryzen 5 2600
650w corsair tx650m 80plus gold
https://linustechtips.com/topic/1211222-pc-not-posting-pcie-issue/
Where do you plug in the hdmi? Ur PSU may also be the reason it doesn't work
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
Simple one to start with; are you supplying the Titan with power from your PSU?
Many 1050 take their power from the PCI-e slot, so you may not be used to wiring a graphics card for additional power...
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
Titans can be power hungry... very valid point; 650W PSU may not be enough.
EDIT:
Of the 26 GTX Titan variants listed on PC Part Picker, ALL have TDP of 250w or more.
WHY NOT...?!
Yeah since it's PSU requirements are listed 600W
Reminder⚠️
Just now, Pkelex said:
as I stated above it worked on my brother's motherboard with the same psu with no problems
What's his specs?
Reminder⚠️
EDIT:
As I stated above I plugged it in my brother's motherboard with the same psu and booted up with no problems
If your PCI-e slot was faulty, your 1050 wouldn't work either...
WHY NOT...?!
1 minute ago, Pkelex said:
same psu as mine a ryzen 5 3600 an rx 5700xt and a b450m pro 4 with 16gb 3200mhz ddr4 ram
Which PCIe connector are you using?
Reminder⚠️
are you referring to the motherboard slot? if so the top one. if you are talking about power connectors im using an 8pin power connector and a 6pin for the gpu
I was referring to the both but try the 2nd mobo slot since some mobos have the 2nd as primary
Reminder⚠️
tried that as well but only thing I got was my monitor flashing to a no signal screen then going to sleep again
Even tho your brother has the same PSU I still think it is it since there aren't really much other factors and it is recomended to have a 600W PSU to run titan GTX
Reminder⚠️
Another thought - what output were you using on the 1050 & is your monitor set to auto-detect the input in use?
That may sound stoopid, but some monitors can be set to specific input.
WHY NOT...?!
I still maintain that if your 1050 still works, the PCI-e slot is fine.
WHY NOT...?!
Found the problem. Changed bios setting from Gen 3 pcie to Gen 2 and it posted
1 hour ago, Pkelex said:
Found the problem changed bios setting from Gen 3 pcie to Gen 2 and it posted
Nice... always better to leave PCI-e detect to auto, that way it'll find whatever card you put in w/o needing to know what Gen. it is.
WHY NOT...?!
Auto should find any Gen. of card... but, OK.
WHY NOT...?!
