So I'm working on getting my parts together to build a home music studio PC/Hackintosh/light gaming rig. I've put together a parts list and PC part picker says it'll pull around 434W, I'm wondering how accurate that is.
Also I'm wondering if I got a 550W PSU if that would be enough and any reccomendations. I have to order through amazon and it's being shipped outside of the US
https://linustechtips.com/topic/1210604-psu-help/
What PSU have you ordered ?
Yea 550 will be more than enough
Your system won't pull more then 300ish watts
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728167
PSU is fine. But for ~300 $ you could get a 10600K (if in stock) and a decent Z490 mobo for 200-250 $ which will perform better in any task.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728188
I haven't ordered a psu as yet, I haven't ordered any parts I'm waiting to order them all at the same time. Is there any that you would recommend?
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728283
Tx550m
Rm550x
MWE gold
Straight power
Pure power
Something cheaper
Cx550 (grey label)
Build Log:
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728288
Are these all brands? Sorry I'm new to the whole PC building thing
Brand has nothing to do with quality
These are models
Build Log:
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728306
Yeh, most brands don't manufacture their own PSU-s only order them form fatcories that produce many product lines to many different "brands"
Life is like a box of chocolates - you have to do a thorough investigation as to what is and what isn't a decent PSU.
Pax vobiscum
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728329
13 minutes ago, zaquedidit said:
I'm working with a $1400 budget so going up wouldn't work out in that budget
I'm not talking about going up in price, it will cost less while performing much better. For your budget you're overspending on your mobo anyways.
PCPartPicker Part List
Type Item Price
CPU Intel Core i5-10600KF 4.1 GHz 6-Core Processor $277.50 @ B&H
Motherboard MSI Z490-A PRO ATX LGA1200 Motherboard $150.98 @ Newegg
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $438.48
  Mail-in rebates -$10.00
  Total $428.48
  Generated by PCPartPicker 2020-06-17 09:23 EDT-0400
EDIT: With this mobo you can easily do an all-core OC to 5.0GHz if your cooler allows it.
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728350
Type Item Price
  Total $428.48
From what I've read newegg doesn't accept international credit cards so I figured I'd just buy everything off of amazon instead, does that motherboard support thunderbolt/have thunderbolt connectivity? I'm just wondering because I know that the gigabyte can be fairly easy to build a hackintosh with and how much of a difference does it make between the brands? Is that i5 better than the i7 that I've chosen?
Sorry for all the questions I'm just super new to building computers and all this, I have a friend helping me but he's also very busy so I've been trying to research as much as possible.
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728373
Ohhh ok, i've seen people recommending sea sonic, corsair and EVGA. I guess they're just well known and trusted?
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728404
Yea well as brands they are mostly good, but the cheaper models are bad.
As stated before me - depends of model.
Pax vobiscum
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728408
Sorry don't know about thunderbolt, i've never used it myself and never looked out for it on any mobos.
The 10600KF also has 6 cores. i5 and i7 actually means nothing in terms of performance or core Count between generations. The 10600K will boost higher than the 8700K. Also the 10600KF supports Hyperthreading, which will help heaps in production workloads. In singe-core tasks it competes with Intels own 9900K.
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728410
Ahhh ok I think I understand now, amazon doesnt have the 10600KF but they have a 9600k, would that be the same situation in terms of performing better than the original i7 I was looking at?
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728426
The 9600K should be cheaper at 200-250 $ and with a bit of tuning should easily overclock to 5.0 GHz all-core and then outperform the 8700K. But in terms of productivity it still has the same problem by not having hyperthreading compared to the 10600K(F).
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728441
After doing some research the programs that I use for music production actually recommend to turn hyper threading off when using them. With that being said what would you recommend in place of the 10600KF?
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728489
What kind of music production? Because Ive seen people buy the new mac pro or even new Threadripper systems for that. Those have a bit more than six threads available.
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728590
I produce anything from hip-hop to afrobeat, to EDM, EDM takes up more processing power though due to the plugins that I have to use to get my sounds. I also record and mix music as well too.
https://linustechtips.com/topic/1210604-psu-help/#findComment-13728607
