Motherboard audio problem
Solved by Light-Yagami,
If reseating all cables and connectors that might be faulty doesn't help, and if reinstalling the drivers doesn't help, it's possible that you've fried something on the MB while you were fiddling with it.
Solution: change the MB or invest in a sound card.
Ramrod126 ·
Posted in Cases and Mods0 -
smush ·
Posted in CPUs, Motherboards, and Memory4 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting6 -
Nebcs ·
1
FancyPants101 ·
1
1
