ryzen 5 3600 90 degrees on stock cooler
hey guys this is my first pc i build it last night and today i was runing a game and the cpu temps are going to 93 degrees ?
what i did wrong to get this high in temps ?
is this normal ? how can i check what i did wrong ?
Update the bios
And monitor your temps with hwinfo64 or ryzen master ( they are the most accurate )
Make sure the cooler is seated correctly and make sure it is a good thermal paste application
Re seat the cooler and put new thermal paste
Phone: Pixel 3a (Purple-ish).
Build Log:
tell me is this how do i do it,   i'll unscrew the stock cooler and wipe the thermalpast from the cpu and stock cooler right ? and then put the new thermalpast on the cpu ?
Yea you remove the cooler
Remove the thermal paste and then nee thermal paste and reseat the cooler
Before that make sure to use hwinfo64 or ryzen master to monitor temps and check your vcore voltage
Build Log:
iam installing it i don't know much ill post a screenshot and tell me if things are good or not
3 minutes ago, TofuHaroto said:
@TofuHaroto should i run a game i nthe backround while using ryzen master ?
Yea for a while
It or hwinfo64
Build Log:
Just now, TofuHaroto said:
Yea for a while
It or hwinfo64
rightnow without gaming this is what i have please wait with me ill post you the numbers while gaming
4 minutes ago, wassil said:
-Snip-
Idle temps look normal
If you want just run cinebench and monitor your temps
Build Log:
5 minutes ago, TofuHaroto said:
Yea for a while
It or hwinfo64
@TofuHaroto this is while gaming
you could always click on profile 1 and then click apply and test to use the built in benchmark
Use cinebench
Build Log:
Maybe you didn't screw it in all the way. For the cooler to make proper contact with the CPU you need to bottom out the screws. They have springs so you can't tighten them too much.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
Just now, Stahlmann98 said:
Maybe you didn't screw it in all the way. For the cooler to make proper contact with the CPU you Need to bottom out the strews. They have springs so you can't tighten them too much.
should i go screw the stock cooler to the max ?
Yes.
No
You'll put more pressure on the IHS
Build Log:
11 minutes ago, GoodEnough said:
any idea why his ryzen master looks so old?
Looks modern to me
Build Log:
4 minutes ago, TofuHaroto said:
Looks modern to me
then why does mine look completely different lol
The stock cooler is not that good, I have quite similar number to that (even worse since it's quite hot in Indonesia) using the stock cooler.
while cinebench , i found a problem in one of the screws i think the motherboard blackplate has a failed hole the screw is not getting tight just turning for nothing what should i do ?
29 minutes ago, Stahlmann98 said:
Yes.
i did i found one of the hole from the backplate motherboard is failed that means 3screws are thighten and one not what should i do ?
here is my temps while gaming , i also found one the hole on the motherboard backplate is failed that means i only screwe 3 until tight and one is just turning without getting tight is this the reason iam getting high temps ?
what should i do ?
8 minutes ago, wassil said:
@TofuHaroto  HELP MAN
If your temps when gaming are fine then don't mind it
From the looks of it gaming temps seen around 80ish
On the high side but totally normal
Build Log:
