The wifi at my house has speeds ranging from 200 mps to 560 mps but whenever i use eithenet the fastest ill get is 20mps. Why is that and how can i make it faster? And to make things worse whenever i download something on steam it takes all the speed i have and uses it all.
Edited by Goku1814
https://linustechtips.com/topic/1210349-i-need-help/
Okay, lets start with the basics. How many devices are connected to the router, and how are they connected?
"Soli Deo Gloria"
IT Technician by trade. Computer/Network equipment enthusiast!
Gaming PC:
  • AMD Ryzen 5 2600X (Stock Core Clock)
  • XFX RX 590 FATBOY 8 GB (Stock Core Clock)
  • Asus ROG Strix B450-F Motherboard
  • Crucial Ballistix 16 GB (2x8) kit 3200 Mhz RAM
  • 512 GB Intel 660p M.2 NVMe SSD (Boot & Current Games)
  • 3 TB Toshiba HDD @ 7,200 rpm (Data)
  • 2 TB Seagate HDD @ 7,200 rpm (Backup)
  • Corsair CX650M PSU
  • NZXT S340 Elite Case
  • 24" AOC C24G1 1500r Curved Gaming Monitor 144hz 1080p
  • Turtle Beach Stealth 450 Gaming Headset
  • Corsair K63 10-Keyless Mechanical Gaming Keyboard (Cherry MX)
  • Logitech G602 Wireless Gaming Mouse, Razor Death Adder
  • Win10 Home
PC Part Picker Link
https://linustechtips.com/topic/1210349-i-need-help/#findComment-13730346
Running speed test while other gadgets are actively downloading/uploading is going to negatively affect your results. So ensure that’s not happening.
If your network is “quiet” and you still get the slow speeds, we still need to know what you should be getting. What speeds do you pay for from your ISP?
Also, have you tried uninstalling and reinstalling the latest network adapter drivers?
And what are the makes/models of all your network components and the type of cable connecting them together? Have you tried a different ethernet cable between the PC and the modem/router?
https://linustechtips.com/topic/1210349-i-need-help/#findComment-13730535
Yes, this is how downloads work unless you want to limit its maximum speed
What are the devices youre trying to connect?
Are you testing the results the same? use speedtest.net or fast.com
Also dont get megabits and megabytes confused, if youre basing wifi devices off of a speedtest.net which displays megabits and then ethernet on megabytes from a steam download it will be different as megabits = megabytes * 8
CPU: i5-4690k @ 4.4 GHz | RAM: 12GB DDR3 1333MHz | GPU: Sapphire Pulse RX 580 4GB
https://linustechtips.com/topic/1210349-i-need-help/#findComment-13730983
