So here i am with my freshly build pc.
Specs:
 2 x 4 GB DDR3
Socket 1150 Core i7 I7-4770 3.5 GHz (Stock cooler)
650 Watt XFX Core Edition PRO650W
MSI Z87-G45 GAMING
Zalman Z11 Plus
GTX 770 Asus DirectCU2 Oc
2 TB WD RED WD20EFRX
55 gb OCZ Vertex 2 (Windows only)
I'm still new at building and i will be upgrading ram and sdd soon or just put in 2 sticks of 8
But i am hoping these pictures surfice :b
Some pictures
https://linustechtips.com/topic/121009-first-build-from-scratch/
Why you no aftermarket cooler? Looks good tho.
Some people don't need an aftermarket cooler, if you're not planning to overclock or do CPU intensive stuff, then the Intel cooler does a decent job, and with some BIOS settings you can even throttle it down to a reasonable noise level
phanteks enthoo pro | intel i5 4690k | noctua nh-d14 | msi z97 gaming 5 | 16gb crucial ballistix tactical | msi gtx970 4G OC  | adata sp900
https://linustechtips.com/topic/121009-first-build-from-scratch/#findComment-1611512
exactly. tho the noise level dosent affect me, i use razer kraken, and they block out like 60 % noise
https://linustechtips.com/topic/121009-first-build-from-scratch/#findComment-1611704
