Hello,
guys and girls of the LTT forum.
I'm once again asking for your tech support. (EPIC OG JOKE. I'm so sorry xD )
This time it is about FPS nirvana. This term describes the insane FPS some folks are getting in their games.
I was wondering how the hellfire they get like 300+ FPS in a game so simple like Minecraft and Leauge of Legends.
So I did some research and found that some games are much more in need of CPU horsepower and other games rely on strong raw GPU power.
In my example, Minecraft is very RAM and CPU hungry.
I have a XEON E3-1231 v3 in my system, which is serving a pretty good job for my mid- to low-end build. So My friend runs a less powerful CPU and is getting like 300 FPS in our Minecraft world. Overall, he is using the same OS and nearly the same settings. But in the same world, I'm only getting something in the neighbourhood of 130 to 150 FPS.
For those who may claim, that it is because of the different settings in-game- Well we compared this with the exact same settings, no resource pack and shader installed. The only mod we used was the latest version of optifine in MC 1.15.2
So if somebody knows why he is getting double the FPS with a slower machine, feel free to reply.
Oh and I maybe have to mention that none apps or other programs were running in the background except TeamSpeak3.
I hope you have a nice week and as always stay safe tech fam.
Yours p0r0x
https://linustechtips.com/topic/1210025-minecraft-and-league-fps-nirvana/
3 minutes ago, Sire_Hank said:
Hi there,
what version of Minecraft are you using?
The java version or the newer one?
What do you mean with less powerful cpu?
What RAM do you and your friend use?
What GPUS ?
Greetings
We are running Minecraft 1.15.2
We both updated Java yesterday.
He uses a CPU with lower clock speed. Maybe I should have chosen another word...
I use Kingston HyperX PC3-10700 2x8gb in DualChannel.
As far as I know my freind is using something similar.
I use a Sapphire Nitri+ RX 580
He uses my old GTX 1050
Hmm
You are sure your RAM is in Dual Channel Mode?
I asked for the "slower cpu" because you java is a little shit and usually works on few cores.
So having a cpu with high clock speeds gives an advantage over multithreading in this rare case.
What Mainboard are you using?
Maybe the pcie lanes are bottlenecking your gpu and cpu?
Hmm
Dont think so. Im using a ASRock H97M Pro4
and cpuz confirmed the dual channel mode
Xeons generally have poor single thread performance especially compared to traditional Intel desktop CPUs. Older titles like LoL and Minecraft cant properly utilize multiple cores so single thread performance is more important.
My stuff:
CPU :  Intel i5 8400 | GPU : MSI GTX 970 Gaming 4GB
RAM : 32GB Corsair Vengeance DDR4 @ 3600MHz
Mouse : Logitech G502 HERO SE | Keyboard : Mountain Everest Max w/ Cherry MX Brown
Headset : Beyerdynamics DT990 Pro 250Ω w/ AT2020USB+
Monitor : Acer XF240H @  144Hz
That's your problem. Radeon GPUs performance in OpenGL is terrible compare to Nvidia GPUs if you're using Java version.
Try Bedrock and compare with your friend?
