Need PC build advice ( €1000,-)
Solved by Stootman,
3 hours ago, Mazdaspeeding said:
This is what I have. I just looked and it's available in Germany. It is a bit more expensive but has a nicer stand with more range of adjustment and a brighter panel. Either are good.
3 hours ago, gloop said:
Thanks for the help guys, I will just look to some more monitors and go with the 5700 xt!
