hey guys
I was just looking at a site called sheep it and I was going to run it on a raspberry pi, but then I realised that I was not running windows and it was not the same way as you do on windows. was wondering if anyone could help me.
link: sheepit-renderfarm.com/
thanks in advance,
Tom
https://linustechtips.com/topic/1209533-linux-noob-needs-help/
27 minutes ago, Mad153 said:
how much time do you have?
its lockdown.
28 minutes ago, Mad153 said:
you're trying to render blender models on a raspberry pi?
I'm just going to leave it on 24/7 for it to gain points by rendering other peoples frames, then when I want to render something I can redeem those points and other people will render for me.
https://linustechtips.com/topic/1209533-linux-noob-needs-help/#findComment-13719231
I assume your Pie is on some sort of Linux.
Make sure you have openjdk installed, if not it should be in your distro's repository as its a fairly common package.
Download the Jar file from the Tux Penguin Icon https://www.sheepit-renderfarm.com/getstarted.php
Depending on your environment, You should be able to click on the jar file to start it.
If clicking on the jar file does nothing or opens a file compression application
  • Open a Terminal
  • cd /path/to/dir/of/file
  • java -jar ./name_of_file_jar
https://linustechtips.com/topic/1209533-linux-noob-needs-help/#findComment-13719878
yes
  • Open a Terminal
did you read the bit of the question where I said I was a Linux noob?
could you point me in the direction of a tutorial that would help, thanks.
https://linustechtips.com/topic/1209533-linux-noob-needs-help/#findComment-13720202
2 minutes ago, Tom_nerd said:
yes
I just gave you a tutorial...
As far as openjdk that entirely depends on your Distro, which at this point is unknown. If its ubuntu, a quick search tells me sudo apt-get install openjdk-8-jre from the terminal. I can not verify this as I run Arch.
https://linustechtips.com/topic/1209533-linux-noob-needs-help/#findComment-13720227
