WiFi-Bluetooth interference
Solved by Electronics Wizardy,
16 minutes ago, Amal Pottanchali said:Thank you brother
. problem solved
i cant use 5G because modem is 2.4G
So First I diagnosed the channels of Wi-Fi and Bluetooth with the help of app in the windows store
( so i could identify that both Wi-Fi and Bluetooth are connected through channel 12)
then I change the channel of Wi-Fi connection in tp link modem settings to 4
problem solved
just saying, with wifi you normally want to only use channels 1,6, and 11 on 2.4g as every other channel is overlapping withone of those.
