Higher benchmark than expected. Not sure to upgrade
Solved by Haro,
11 minutes ago, Twi5tedw3lsh said:was looking at a 1650s
How about the 1660 super ?
12 minutes ago, Twi5tedw3lsh said:The pc has been tested over the last 2 days using stress tests, benchmark and gaming, temp doesn't exceed 76(one burst into 80 for about 5 seconds until the fans went into a faster cycle)
Dont mind stress tests
You will never encounter such workloads as a casual user
If you happy with the current performance keep it and wait for next gen
