IRQL not less or equal BSOD error
Solved by Fred Castellum,
Cool then, hope you fixed it. I personally have run my ram on 1.65 volts without my knowledge ( I didn't check) for over 6 months before I went back into the bios to play around with some settings on my CPU overclock and I noticed it. didn't do any harm to my sticks at all and would have changed back if they didn't run stable at 1.5v anyway. (all 4 my sticks are kingston 1333s running at 1600)
Okay, well I would just do what your doing and update your drivers. That might fix it.
Everything's running stable now thanks for the assistance, after loosening timings the mem tests passed with no problems and I'm not longer getting BSODs. I can work without interruptions now! ![]()
