Browser, version and OS: google chrome, most recent windows 10,
Steps to reproduce/what were you doing before it happened?
Problems since I received the pc
What happened?
well first i was getting weird screen like all pixal with weird smybol and now it keep restarting with a long and loud beep after getting weird symbol. thought it was monitors but it not. i check both cables along with both monitors. then i thought somthing was lose like graphic card. checked that and that seems fine.
After looking into it  I think it may be overheating or possibly the psu dosent have enough power for the unit
What did you expect to happen?
Link to a page where it happened, if applicable:
Screenshots of the issue, if applicable:
Any other relevant details:
CPU: Ryzen9 3900X
GPU:Nvidia 2080TI
Motherboard:Asus x570 TUF  Gaming-plus
PSU: corsair TXM seares
Ram: corsair ddr4 3000 Mhz
If it's a cloudflare error, what was the ray ID from the bottom of the error page?
https://linustechtips.com/topic/1208451-need-help/
3 minutes ago, Cruz vigil said:
Also just found this and I'm not sure what it is for
That's a POST speaker - allows POST to give you beep codes.
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1208451-need-help/#findComment-13710379
Looks like GPU artifact, Contact the seller and start talking about warranty replacement.
Gaming Build:
CPU: Ryzen 5 3600x (4.3GHz)  |  GPU: MSI 1070 Ti Duke  |  MotherboardASUS Prime X570-Pro  |  RAM: Crucial Ballistix DDR4 3200 32GB
https://linustechtips.com/topic/1208451-need-help/#findComment-13710398
-> Moved to Troubleshooting
I get that FORUM Bugs and Issues is on top, but please read before posting.
You have most likely dying GPU. Test with another GPU since you don't have iGPU.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1208451-need-help/#findComment-13710408
