I only have a monitor with one single input with it. Plus it is only a VGA monitor. I always have to switch the cable from the PS4 to the PC vice-versa. Cables look meh. I zip tied the cables of the monitor and PS4 on the back of the stand of the monitor. Please give me advice to make my setup look better..... Thankssss.
https://linustechtips.com/topic/1207700-cable-management-help/
Mount the PS4 to the side of the cabinet on the left, move the power-strip under the table, get a KVM or similar so you can switch between PS4 and PC with a simple button...
https://linustechtips.com/topic/1207700-cable-management-help/#findComment-13704527
18 minutes ago, medyobano said:
PS4
Here's how I mounted my PS4 to a TV-stand:
I 3D-printed those holders, but you can pretty easily craft something similar out of scrap-wood or anything and then just paint them according to your tastes.
4 minutes ago, medyobano said:
Unfortunately my desk is mounted on the wall. Any solutions to that? Thanks btw for the help so far
Drill a hole to the back of the desk so you can get the cables through.
https://linustechtips.com/topic/1207700-cable-management-help/#findComment-13704556
