10 minutes ago, LiamGuff said:
Does anyone have any recommendations on a stand alone wireless mic because when I look it up I can't find any or it are microphones for singing. Thanks
Are you looking for something like the modmic wireless?
https://www.amazon.com/Antlion-Audio-Attachable-Microphone-Headphones/dp/B07KQF165L
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/1207335-wireless-microphone/#findComment-13701806
nope, he specifically said stand alone
CPU: AMD 3600X
GPU: Nvidia 3070 (planned)
motherboard: MSI B500-A PRO
memory: G Skill Ripjaws V 2x8 GB 3600Mhz CL16
PSU: EVGA B3 650@
Case: NZXT H510
wireless network adapter: intel ax200
https://linustechtips.com/topic/1207335-wireless-microphone/#findComment-13701869
For the record I think this is a stupid idea but if you really want a wireless mic there are tonnes of options similar to the Alesis MicLink that allow you to use real XLR studio microphones as wireless mics. Again, it's a silly idea and you should just accept the cables considering you need a stand to hold it in front of you in the first place that a cable can run along.... But that's a solution.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1207335-wireless-microphone/#findComment-13703168
