A couple of days ago, my PC suddenly shutdown while I was gaming.
No smell or sound when it occurred.
my PC wouldn't post after that.
Initially to avoid a full disassembly;
First i unplugged all external stuff expect for power plug, no luck.
Then I tried changing the CMOS battery of my mobo, no luck
Then i check if my PSU was still functioning with the included PSU test, PSU was fine.
I swapped in another PSU just to make sure, no post, PSU wasn't the problem.
I went forward with a full disassembly.
I connect by mobo plus a fan with the PSU, mobo turns on, lights on mobo displays successful post.
Then i pluged in my GPU and connect it to the PSU, no post
I removed the power from the PSU to the GPU, got a post
So now i need help finding if the GPU or part of the mobo is dead.
Sys
i7-8700k with Noctua NH-D15
Asus ROG Maximus X Hero(ac wifi)
4x 8GB Trident Z RGB 4x8GB 3200C14
Gigabyte OC Gaming 1080ti
EVGA T2 1000W
https://linustechtips.com/topic/1206423-pc-physical-troubleshooting-help/
Most probably the GPU is dead ?
Did you try another PCIe slot ? (with GPU power connectors plugged in)
if it still doesn't work then rip GPU.
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
Your cpu has a gpu in it one thing to try might be to remove he gpu card, plug your monitor into the motherboard video out and see if it works.  If it does it’s a discrete gpu problem.
