I have a modded server with some lightweight mods, it randomly stopped working at Locale en_US in the command line then it stops, it worked yesterday. The other issue is that when we assign more than 1gb like 2gb it will just say could not reserve space in task manager it says only 1gb of 8gb is currently used before starting still when I start server just won't work, note the latest java is installed
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1205928-minecraft-server-problems/
Try reinstalling java (the 64 bit version).
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
Also try to recreate the server with the same world and mods.
Solves most of the issues.
This issue came after java reinstall, the one where it stops at locale the one where I can't add more ram was the reason I reinstalled java, if it is to help the pc is remotely accesed via teamviewer
Reminder⚠️
Did u install specifically the Windows Offline (64-bit) version ?
try this command in cmd: java -version
does it report as 64 bit ?
Yes it reports as 64 bit
Reminder⚠️
Try to set up a new server with the same mods, world, and config.
Minecraft servers tend to become buggy after updating java.
This usually solved all the problems i had.....
Only get this error
Reminder⚠️
11 minutes ago, Kanna said:
Only get this error
try 1.5gb....
it sounds like you have 32 bit java.....
that's weird.
add -d64 to the launch arguments
-deleted-
12 minutes ago, Void Master said:
try 1.5gb....
that's weird.
is there any log file i can send?
Reminder⚠️
there is the server.log, but that's only useful in case of conflicting mods....
if you go to programs in control panel, does java show as 64 bit ?
i am sure minecraft is using 32 bit java, do you have both 32 and 64 bit versions installed or only 64 bit ?
try to uninstall java are reinstall the windows offline 64bit version from: https://www.java.com/en/download/manual.jsp
Thanks for helping that fixed the problem
Reminder⚠️
You're welcome.
