There will be an image below showing the parts that I have chosen and what the issues/warnings mean (my dad wants a PC for a bunch of office work and his budget is around 2k, not for gaming, and wants it future proofed for a couple of years)
The screenshot is from PC part picker
https://linustechtips.com/topic/1205576-i-need-some-help/
the errors are saying "your SSD might be bottlenecked because if you use this one slot you will share bandwidth with a SATA (just use a different M.2 slot)" and they are saying they can't detect if the cooler won't fit over the RAM
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1205576-i-need-some-help/#findComment-13686950
not much to worry about unless there is only one M.2 slot and you want a SATA
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
https://linustechtips.com/topic/1205576-i-need-some-help/#findComment-13686952
1 minute ago, Laller Baller said:
SSDs are faster than SATAs right?
And thank you  ALOT for the help!!!
SATA is a type of SSD. M.2 is also SSD. Different form and different speeds.
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
https://linustechtips.com/topic/1205576-i-need-some-help/#findComment-13686969
10 minutes ago, The_russian said:
M.2 SSDs are faster than SATA SSDs, m.2 and SATA are both interfaces for SSDs.
M.2 is the physical form factor. There are tons of SATA M.2 drives. There are also NVME M.2 drives.
MacBook Pro 16 i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME
iPhone 12 Mini / Sony WH-1000XM4 / Bose Companion 20
https://linustechtips.com/topic/1205576-i-need-some-help/#findComment-13687022
