So, whenever I start a game (most recent ones like CoD: Warzone/Apex Legends) my PC blackscreens and my fans start spinning at 100% speed. I tried changing my PSU. It didn't work, I tried dusting the whole PC, still does the same thing. It's my first build and I'm pretty scared to do anything without professional or someone's informed advice. I don't want to break anything. My build has a Ryzen 5 3600X CPU with a RTX 2060 Super GPU, 32GB DDR4 RAM, a Samsung 970EVOPlus 500GB SSD, 2TB Seagate BARACUDA HDD and a Corsair RM750X PSU. Thank you in advance, I'm looking forward for advices.
https://linustechtips.com/topic/1205491-urgent-help-needed/
Run lower memory frequency when DOCP is enabled.
Desktop benching:
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13686095
4 minutes ago, Pres0 said:
Could you please tell me how to do that, because I literally have no clue what DOCP and how to do it x) I'm sorry for being so oblivious.
What memory kit do you have?
Desktop benching:
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13686114
7 minutes ago, Pres0 said:
Corsair Vengeance LPX 8 GB DDR4-3200 DIMM 288, and I have 4 of those.
But you did not turn on XMP.or DOCP?
Desktop benching:
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13686129
Make sure you didn't broke the pins on the processor because i have face these problems on many intel processors.May the same apply to ryzen cpu's
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13686134
10 minutes ago, Pres0 said:
I don't think so, since I have no idea what that is..
The go find that option, should be in the menu where you do overclocks. Depending on the board you will need to select frequency as well, try 3200 and if it crashes, 2933
Desktop benching:
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13686280
My board is AsRock B450M, I have to say, nothing from my stuff is overclocked. But where do I find that option? Somewhere in the BIOS?
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13686362
OC Tweaker?
Desktop benching:
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13686374
8 minutes ago, Pres0 said:
Could it be something from my GPU overheating? Although I look after it with MSI Afterburner and it's always at around 70 Degrees Celsius
Unlikely. They just underclock when they get too hot
Desktop benching:
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13687592
26 minutes ago, Pres0 said:
Can you link me "OC Tweaker" if that's a name of the program I need to find? Really appreciate all you've done to try and help me so far :)
That's the name of a submenu in the BIOS
Desktop benching:
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13687718
Should docp not do stable profiles though? See because I have this issue when o oc to 3600 and I’ve been told to rma my mobo but I cba yet. Isn’t there a chance something is faulty?
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13687743
There's always a chance for something to be faulty, but I have no clue what is.. It was fine like a couple of months ago, it started doing all this recently.. it's really stressing me
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13687784
turn docp off and try running games and see if it still crashes.
what ram are you using and what motherboard?
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13687793
Profile ratings on memory sticks are just for the sticks, not for board or CPU, strictly speaking.
Desktop benching:
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13687871
Motherboard can have issues running the ram at rated speeds though. Don’t ask me how as I forgot know all I know is I have this issue and fixed it buy just not running the oc until I can be a to get my mobo rma’d
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13688062
So.. in short, what should I do now? You guys confused me even more haha
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13688187
Where do I turn that off?
My Motherboard is AsRock B450M
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13689302
photos screenshotted from youtube video.
try setting that setting to auto so the opposite of what this guy is doing
https://linustechtips.com/topic/1205491-urgent-help-needed/#findComment-13689324
