15 minutes ago, Nick Neuburg said:
well idle as in sitting with a nothing or a tab open or something else cause i don't think ive ever seen it below 4.4
NZXT's software cannot track idles and has frequent misreadings. Only Ryzen Master and HWiNFO will accurately report your system performance. Don't trust ANYTHING NZXT cam shows you.
https://linustechtips.com/topic/1205248-clock-speed/#findComment-13684357
I don't use CAM I look at taskmanager for clockspeeds
https://linustechtips.com/topic/1205248-clock-speed/#findComment-13684468
9 minutes ago, NZgamer said:
Idle as in maybe one light program open, not doing anything intensive. My 3200G sits around 3.2Ghz with Firefox, Discord and Spotify open
It depends on what is running in the background / foreground, and what power saving features / settings are enabled or disabled.
For my system, it I set the power plan to 'Balanced', it will jump around randomly...800 MHz, 4.3 GHz, 2.5 GHz, etc.
Setting it to 'High Performance', it is more stable sitting at 4.2GHz ~ 4.3 GHz.
CPU load hovering at around 2% ~ 5%.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1205248-clock-speed/#findComment-13684504
