I can only assume that this is some kind of electrical noise being produced by my PC. All windows in the room were closed, chasis fans as low as they could go, ceiling fan off. I did a second run with the GPU fans screaming at 100% but it didn't sound like the mic was picking that up as there was no change in the audio.
Audio Setup:
Mic: Audio Technica AT2020
Interface: Behringer U-Phoria UMC22
Power: Furman SS6B Power Conditioner (advertised as having "EMI/RFI noise attentuation")
PC:
Motherboard: Asus PRIME Z-390-A
GPU: 2x SLI MSI GeForce GTX 1080 Armor
CPU: i7 8700k OC to 4.9 GHz
PSU: EVGA Supernova 1000G 80+ Gold
RAM: Corsiar Vengeance LPX 4x4gb DDR4 3000 CAS15
CPU Cooling: CoolerMaster ML240L RGB
Recording.m4a
https://linustechtips.com/topic/1204806-electrical-noise/
1, That's not a power conditioner
2, It's unclear whether you mean mic noise or speaker noise, is this being picked up by your mic or is it coming out of your speakers?
If that's what your mic is picking up there are a few possibilities,
1, Gain is too high,
2, Poorly shielded XLR cable
3, Lots of EMI in your room
or
4, EMI interference over your USB ports.
If you just want to get rid of the noise there are a tonne of noise removal plugins and programs that can get rid of it for you, if you want to find the source of the noise that's going to be a tad more difficult.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1204806-electrical-noise/#findComment-13681382
