Hello so my graphics card recently started doing strange things, I don't know what to do. When i turn on my computer it starts flickering showing strange stuff on screen and crashes after 1 minute. GPU is ~6-7months old. Sadly RMA is not an option.
GPU - RX580 8GB SAPPHIRE
PSU - XFX PRO450W
CPU - R3 2200G (when i use igpu problems stop)
RAM - 8GB HYPERX 2666mhz
https://linustechtips.com/topic/1204175-rx580-dead/
2 hours ago, Datsungaming said:
I have problem with my rx580 gb8 sapphire pulse. I see other people having problems with it to. Has anyone found a fix?
lol good thing I sold mine then. I didn't have a problem. Have you changed drivers before the problem?
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/1204175-rx580-dead/#findComment-13692271
PSU - XFX PRO450W
6-7 months old as in you bought this new 6-7 months ago? Why wouldn't RMA be an option? Unless, you bought this card used 6-7 months ago and the actual age of this card is way older.
https://linustechtips.com/topic/1204175-rx580-dead/#findComment-13692285
Is this psu even powerful enough to power that gpu ?!?
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
https://linustechtips.com/topic/1204175-rx580-dead/#findComment-13692691
Technically yes
Ddu ?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1204175-rx580-dead/#findComment-13692696
