So this morning when I turned on the pc, everything was fine, but my mouse paused. And then my screen turn off, and the pc was still running, but low sound, and when I press the on button to reset it, it turned on with spikes on gpu like two spikes and hdd and ssd, but after windows finished doing its thing it looks like this:
specs is 8 Gb ram ddr4 3200mhz, r5 1600, gpu Radeon rx 480, and ssd, and hard drive of 500gb, 500 psu. Idk if I’m freaking out over nothing but I wanna make sure everything is good
https://linustechtips.com/topic/1204135-weird-thing-after-booting-up/
Update the bios
Use ddu
Make sure you have xmp
If you do disable it and then see
Phone: Pixel 3a (Purple-ish).
Build Log:
6 minutes ago, TofuHaroto said:
Update the bios
Use ddu
I’m new at this lol, wdym use ddu? And Xmp means using all your ram speed? If not what is it? And my bios is up to date I think, I updated like two weeks ago, but let check tho
1 minute ago, AaronG 21 said:
wdym use ddu?
Display driver uninstaller check a video on how to use it
It allows you to run your sticks at their advertised speeds
Make sure it is on within the bios
Build Log:
