DAC (Schiit Modi) making insanely loud noise
TheSuperSawm
Hey LTT community,
I have something happening to my DAC upon startup which is kinda crazy and really loud in the ears. It sounds like mega static and it only goes away if i unplug everything and then plug it back in like a year later. Does anyone know what the cause is?
Check the video for the sound.
Thank you,
TheSuperSawm
That is weird. Maybe try to change all cables or clean them. Either that or you have to get a new dac. That dac is kinda old and outdated tbh.
PM or DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
Beyerdynamic Tygr 300 R w/ Dekoni Velour as daily driver
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Keyboard > SteelSeries Apex Pro
Mouse > Steelseries Aerox 3 wireless
Mousepad > Pulsar ParaSpeed XXL
VR > Valve index kit
Read this post if you want a "gaming" headset ;)
@Tigerleon @rice guru
Thank you both for the replies. It just seems that I have issues with the DAC so often that it is likely that I will have to buy a new one (unfortunately). I don't want to dish out the cash but whatever lol.
Thank you both again.
I'd message schiit and find out if they can do anything for you, I've not heard complaints about their customer support.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
@The Flying Sloth Thanks for the advice. I'm not sure  what they would do for a six year old product, but it can't hurt to try, right? :)
Perhaps not but they may have advice on what went wrong and/or how to avoid it in future.
@rice guru
They may have infor on why it's happening and maybe a fix for it but you most likely will need a new dac
