Best wireless headset for under 100 USD
Lilninjsways
I would love a good wireless gaming headset with minimal latency and best audio quality and good battery life I do not need a mic at all as I have a standalone microphone
I would love to get the best bang for your buck.
I found a steel series one https://www.amazon.com/dp/B07X64MTGL/ref=cm_sw_r_other_apa_i_rRx1EbTAKHS8Q
I have heard good things about steel series. If you need a good comparison of what I have currently I have a razer kraken pro v2 (USB)
I don't really mind range too much? Just enough to get across a bedroom without disconnection. 😅 I don't need to travel across my apartment or anything
MY MAIN BUILD AT FATHERS HOUSE!
CPU: AMD FX-8300 3.3GHz 8-Core Processor CPU COOLER:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard
RAM: 32gb ddr3
Hard Drive:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Graphics Card:  MSI Radeon RX 470 DirectX 12 Radeon RX 470 ARMOR 4G OC 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Case: Rosewill TYRFING ATX Mid Tower Case
Network Adapter:  TP-Link TL-WN781ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
Case Fans:  Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan (PLUS THE STOCK CASE FAN)
Monitor:  Asus VG248QE 24.0" 1920x1080 144Hz Monitor
Keyboard:  Thermaltake CHALLENGER PRIME Wired Gaming Keyboard
Mouse:  MSI Interceptor DS B1 Wired Optical Mouse
Speakers: Logitech Z200 0W 2ch Speakers
