Hello everyone, i have CM 212 EVO cpu cooler.Since ive done some overclocking im getting higher temps and for that purpose ive bought 1 more Cpu cooler Fan(a bit better one). My question is , on which side should the better cooler be and why , i intent to keep them both still on cpu cooler its just the orientation im confused,BF=betterfan, WF=worsefan , <BF<CPU<WF< or <WF<CPU<BF<. I know the question is kinda confusing but my english aint the best, thank you
https://linustechtips.com/topic/1203230-best-cpu-fan-position/
the blowing air install it to the exhaust back fan position
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1203230-best-cpu-fan-position/#findComment-13667856
6 minutes ago, Asukaa said:
<WF<CPU<BF<
If the better fan is blowing though the cooler from right to left, and worse fan is "sucking" whatever it can, from CPU cooler and all the heat is directed at the case  exhaust fan, it's all good.
Theoretically....
Pax vobiscum
https://linustechtips.com/topic/1203230-best-cpu-fan-position/#findComment-13667865
The difference between these configuration would likely be very, very small, you probably will not notice. As long as the airflow is all going in the same direction, the fans will do their jobs.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1203230-best-cpu-fan-position/#findComment-13667870
Neither. An extra fan on a 212 EVO will do nothing for you other than increased noise. The heatsink isn't thick or dense enough for push/pull to make an appreciable difference. I'd put the better fan on the 212 and mount the weaker fan as an additional intake or exhaust, depending on your system's current airflow.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/1203230-best-cpu-fan-position/#findComment-13667898
well, my own tower sees a small benefit from the second fan, it's worth experimenting to see if the second fan improves temps
currently using the 212 evo with the stock fan and an RGB Riing fan.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1203230-best-cpu-fan-position/#findComment-13667903
Huh, interesting. I was running a 212 EVO with matched dual fans on...I think...an FX 8350 in one of those CM HAF monsters from the early 2010s. I saw no difference, but the HAF 932 was basically a massive cheese grater with perfect airflow anyway.
Goddamn, I miss that case. There are a few decisions I wish I could have back, and selling that case is one of them.
https://linustechtips.com/topic/1203230-best-cpu-fan-position/#findComment-13667929
An additional fan can definitely help but whether the difference is easily seen depends on how it's tested.
@Asukaa What fan did you get? From an old LTT video, it seems like the fan with more static pressure would be better in push.
https://linustechtips.com/topic/1203230-best-cpu-fan-position/#findComment-13668510
