For a long time ive been trying to forward ports (mainly for a minecraft server) but the usual method from the router settings doesnt work, it just does nothing, even if i make firewall rules. The only way ive managed to open a port is by setting it as the connection port in utorrent. That works but it only lets me open 1 port and it only works for my pc (i cant forward a port for a local file server). Is there anything im missing? I have a ZTE zhxn h267a v1
https://linustechtips.com/topic/1202866-port-forwarding-help/
Have you talked to your ISP? Some invoke limits on what you can do with Port Forwarding.
Assuming you have:
  • The correct IP
  • The correct port number
  • TCP, UDP, or Both set correctly
And you're not behind a Double NAT under most circumstances those are the only prerequisites to Port Forwarding successfully.
https://linustechtips.com/topic/1202866-port-forwarding-help/#findComment-13664989
Assuming you have:
  • The correct IP
On my ISP's website there are even a few guides on how to port forward on some of their router's (not mine) so i would think its not restricted. Here is a screenshot of my settings
https://linustechtips.com/topic/1202866-port-forwarding-help/#findComment-13665006
https://linustechtips.com/topic/1202866-port-forwarding-help/#findComment-13665034
Firewall rules on the server or on the router? You'll need to allow the ports through the firewall on the Minecraft server.
For Windows
https://www.google.com/amp/s/www.tomshardware.com/uk/amp/news/how-to-open-firewall-ports-in-windows-10,36451.html
For Linux/Ubuntu.
https://www.ibm.com/support/knowledgecenter/STXKQY_5.0.4/com.ibm.spectrum.scale.v5r04.doc/bl1adv_firewallportopenexamples.htm
https://linustechtips.com/topic/1202866-port-forwarding-help/#findComment-13666136
For Windows
For Linux/Ubuntu.
Thats exactly what ive done
https://linustechtips.com/topic/1202866-port-forwarding-help/#findComment-13666144
Okay. Looking at the image you posted, for the WAN IP try adding your Public IP address.
This is what is shown on here:
https://portforward.com/zte/zxhn-h267a/
https://linustechtips.com/topic/1202866-port-forwarding-help/#findComment-13666155
Still nothing, does the "WAN Connection" matter? mine is HSla whereas in the screenshot its PPPoe. That option isnt showing up on mine.
https://linustechtips.com/topic/1202866-port-forwarding-help/#findComment-13666167
https://linustechtips.com/topic/1202866-port-forwarding-help/#findComment-13666197
7 minutes ago, tripaloski said:
Yeah as you told me to, i typed my public ip there but it still doesnt work
Oh. Sorry. Miss read. :) Stupid question, is the server actually on? Also, you might need to take a look at the Minecraft server properties to check whether the ports are correct.
https://linustechtips.com/topic/1202866-port-forwarding-help/#findComment-13666222
to test every change i make i use an online port tester like canyouseeme.org and the only time i have got an open port result is when i use utorrent. And the server perfectly works with utorrent so the only thing thats going wrong is the port forwarding
https://linustechtips.com/topic/1202866-port-forwarding-help/#findComment-13666243
