Issues understanding R5 3600 behavior.
2 hours ago, JonnMcDude said:Thank you for the reply.
I understand, I need to change the way I see things because I was not prepared to this situation; I'll try to play a bit with the cpu fan profile.
Gigabyte provides an application with fan controls (it mimics the bios settings), do you know if it's not recomended? I find it kinda useful because if it works as advertised then I don't have to constantly jump to the bios for a little tweak in the graph.
What about ram? Is XMP a viable option if I can't properly tune it due to lack of customisation in the bios?
Ryzen Master, is it any good? Is auto oc actually decent or should I leave the cpu as it is with stock values?
Motherboard, since I am out of the loop (last I purchased was in 2015 I believe) which brand does provide a good BIOS experience?
Voltages are in line with what I just learned.
1. In regards to the Gigabyte software, I have no personal experience. I'm using an Asus board, so I can't vouch for it. But if it works fine, then I'm sure you're good.
2. You REALLY should run your ram in XMP. If you don't it's just a waste of money, and your ram is running slow. If you want to tweak it in your bios for better performance than that's on you, but XMP is really the baseline for ram. Running without XMP is just lost performance and wasted money.
3. I like Ryzen master. It's nice to be able to tweak everything in your desktop quick and easy. But I'd recommend setting everything in the bios after you have it all set up and stable.
4. I currently have PBO + AutoOC (with I think a +200Mhz offset, whichever is highest) enabled on my 3800x. It seems to work fine. I would recommend using something like CInebench R20 to benchmark, and run it with PBO on/off, and AutoOC on/off to see the performance difference relative to the temperature difference, and see how it is on your particular chip.
5. I love my Asus board, but I don't think you should have any issues with Gigabyte, Asus, Asrock, or MSI.
If I can also add one thing, since you're coming from an OC'd 4790k, is please do extensive research into OCing Ryzen 3000 before you consider overclocking it. IMO it's not worth it to OC Ryzen 3k, but my opinions aside, there's very little headroom to OC, and without proper knowledge about your specific chips max voltage, etc, and doing the right testing/info gathering beforehand and just jumping right into OCing you can permanently degrade the silicone in your chip.
Personally I only ever recommend PBO + AutoOC on Ryzen. Manual OCs just aren't worth the risk/hassle, and you can lose gaming performance.
Best of luck.
