9 minutes ago, Hyroshi said:
Hmmm, have you looked in device manager to see if it picks up anything? (I'm assuming that you're running Windows)
Another thing you could check is, does this cable and/or hdmi port work with audio on other devices?
I'm running 10 pro. So the HDMI cable was plugged into a Nintendo switch and sound worked fine And it's getting late so I'm calling it for the night so I can get back to you tomorrow about if device manager picks anything up
https://linustechtips.com/topic/1573017-audio-issue/#findComment-16433589
Went into device manager and it shows me AMD high definition audio device, high definition audio device, and Nvidia high definition audio device
https://linustechtips.com/topic/1573017-audio-issue/#findComment-16433947
I clicked on the sound icon in the bottom right and I clicked on Nvidia high definition audio device output and it says restart your PC to finish installing drivers and updates And I did that but still no output devices found. Do I by chance need a sound card for this to work?
https://linustechtips.com/topic/1573017-audio-issue/#findComment-16433951
