Ryzen 5 3600 cooling
Solved by HippY,
I am in the exact same boat, core temp reports around 60 C° temp when I am just watching a 1080p stream and web browsing, which is outragous.
What I see is the voltage is really high (1.4V when watching a stream) and the CPU is boosting all over the place rapidly, so it might be a cooler issue (I will change it if I see a sale or have funds, its a bit small) but it can be a boosting issue, check these numbers.
I will try to find more information on this behaviour
