Whilst i am pretty sure it is normal for my gpu to get around 70-80C at load, i don't know if it's normal for the actual back plate to burn my finger when i touch it... I have a GTX 1080 G1 and plenty of airflow throughout the case (2x 140mm in the front and 2x 120mm exhaust in the back). I don't want to waste people's time with this but i don't want to blow up :) Thanks!
https://linustechtips.com/topic/1202513-are-my-temps-normal/
As long as you are only getting those temps when under load, you should be fine.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1202513-are-my-temps-normal/#findComment-13662245
80c is 176f.  That would burn my finger.
https://linustechtips.com/topic/1202513-are-my-temps-normal/#findComment-13662273
