Is 1440p@240hz HDR possible with DP 1.4a?
By
Cool Toolbar
in Displays
in Displays
Solved by Glenwing,
The maximum limit of each interface is in a table on the left hand side of the calculator. The maximum data rate of DP 1.4 is 25.92 Gbit/s. So 8-bit would be possible, 10-bit would be outside the limit.
8-bit + FRC is a 10-bit signal in transmission, so it does use the same bandwidth as a native 10-bit panel would.
Featured Topics
Hotblood ·
Posted in CPUs, Motherboards, and Memory1 -
6
6
UGAATL ·
Posted in LTTStore.com Merch1 -
1
8
Mark Kaine ·
Posted in Displays4 -
3
4
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
