first time build help
Solved by blu4,
4 minutes ago, TeaAitchSea420 said:
Thats a B450 board witch is a good board I think its just PCIE for the m.2
B450 are very good if you do not want to pay for the x570 ones. but you wont get PCIE 4.0
PCIE 4.0 is not needed but like I said its future proofing. If you don't play to get a next gen card any time soon like next 2-3 years id stick with a cheapr board. id get a b450 over others personally
