I need help finding a new case, i will attach a photo of my current one. It will need good airflow or would it be the time to move to custom water cooling because i will probably need to buy new fans and a new radiator for my cpu or else itll look really weird. i currently dont have a problem with aesthetics since my current case does not have a tempered glass side, i have the Corsair Carbide Series 100R Silent Edition. my current temps running at stock are about 70-80 'C during 1440p gaming max everything. What are some good case suggestions and should i make my move to custom water cooling?
https://linustechtips.com/topic/1201572-i-need-help-finding-a-new-case/
Nzxt h510 or deepcool matrexx 50 both for around 60 bucks in the US I would suggest water cooling for builds with 2080ti's or multi gpu systems but for a normal system with a 1080ti just get one of those 2 cases and slap some fans in there and u will be good
its 2x 1080Ti and i am running an 8086k but cant really overclock too much without crazy thermals. the H510 is a bit small and not enough airflow for the intake, same with the deepcool. id also prefer a case with a mesh filter. thanks though
Something like a p400a for an atx build
For airflow it is exceptional
Phone: Pixel 3a (Purple-ish).
Build Log:
1 hour ago, RyanPeckeroony said:
I was actually looking at the p400a but it was sold out last time I checked. I'll look into it again
I run the p400s and the p400tg. Neither of mine have the front mesh panel but I still love the case. Tons of room for large gpus but for water cooling, the rad would have to go on the front panel. It's to tight at the top for a rad.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
If you can't fine the p400a
The p300a is still a contender
It's basically the same but it just comes with one less fan
Build Log:
