Hi guys,
so for years I've been using the Logitech G700s as my bluetooth mouse with no issues at all.
Recently though i bought myself some Bluetooth headphones (EKSA E5 Active Noise Cancelling Headphones). At first I was happy with my choice but especially during gaming
I noticed there were occasions when my game would seemingly lag - with 150+ fps.
After a while I also noticed random missing audio for brief moments which is especially unfortunate in FPS-games.
I came to the conclusion that it had to be a bluetooth related problem most likely being caused by the two devices interfering with each other
throttling the other peripheral's transmission rate in a way. To make sure its not caused by my router which is also close to my PC i switched to
5Ghz on my WiFi which didn't help either.
Is there any way I can use both devices or do further troubleshooting? Any ideas?
Just to clarify: If i use my mouse as the only Bluetooth device with another headset, it works fine.
Same goes with the headset with my mouse turned off.
https://linustechtips.com/topic/1200183-issues-with-bluetooth/
Your best bet is to return the headphones and buy a wireless set from Logitech. Radio bandwidth is limited and it's not surprising that one manufacturer's chosen frequency/modulation would interfere with another's.
https://linustechtips.com/topic/1200183-issues-with-bluetooth/#findComment-13645159
