3 minutes ago, emosun said:
apu's aren't selectable or changeable , they are embedded into whatever cpu they are in. pick a cpu and whatever apu it has is what it has , thats it
yeah he means that hes searching for a good cpu that supports ddr3 that also has graphics
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1200066-apu-help/#findComment-13644059
1 minute ago, emosun said:
and here i was all reading what he typed instead of making up my own question for what i think he wants , silly me
yeah well if he wanted a "pick whatever" answer he wouldn't ahve come to this forum now would he xd
https://linustechtips.com/topic/1200066-apu-help/#findComment-13644070
Technically an APU refers to a CPU with an IGP, not just the IGP, so the OP would be correct to ask which APU is good.
https://linustechtips.com/topic/1200066-apu-help/#findComment-13644090
well i'll agree with that so long as nothing from the manufacturer claims the product to be a cpu , sure then
https://linustechtips.com/topic/1200066-apu-help/#findComment-13644098
1 hour ago, emosun said:
What board are you using. Whats the budget . Whats the use case
Well let me start at the beginning. I'm using a fairly old laptop (HP 2000 Notebook to be exact) and I'm trying to upgrade the parts. The board is an HP 188B motherboard (sorry if that's vague thats literally all I could find)
My Budget is $200 or under
https://linustechtips.com/topic/1200066-apu-help/#findComment-13644403
Which specific HP 2000 laptop to you have?
Are you also able to tell us what the laptop CURRENTLY has?
Run CPU-Z and upload a screenshot of the following tabs:
  • CPU -- tells you EVERYTHING about the current CPU (make, model, revision, socket type, etc)
  • Mainboard -- tells us a bit more information about the HP 188B motherboard (make, model, revision, chipset, BIOS version, etc)
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1200066-apu-help/#findComment-13646512
