4 hours ago, Eslitened said:
If your GPU is not running at maximum usually means that your framerates is lock at certain level. Often through in-game or your graphic control panel limiter or V-sync.
i have ingame vsync off.  nvidia control panel, max frame rate off. Vsync is on default. It does go over  75 fps which is my refresh rate but it doesn't use all the gpu power
https://linustechtips.com/topic/1200006-gpu-not-using-100/#findComment-13644625
What's your CPU usage?
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
https://linustechtips.com/topic/1200006-gpu-not-using-100/#findComment-13644628
