Broke my pc. Need some help
Solved by js23,
Unplug the drives you don't want and use the windows installation media to delete the partition on the main drive and create a new one to reinstall windows on. I usually do a fresh install about once a year to clean up the junk anyways, with Windows 10 its easy to do, and if you need a new windows key you can get oem keys for cheap.
ShayOh ·
Posted in Troubleshooting0 -
Newbietobe5467 ·
Posted in Troubleshooting2 -
1
robjt ·
Posted in Troubleshooting12 -
4
4
Dixel ·
Posted in Troubleshooting11 -
Gerowen ·
Posted in Troubleshooting5 -
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
