Budget (including currency): 1500-1600$
Country: US
Games, programs or workloads that it will be used for: Video/photo editing focused. Premier Pro, photoshop etc.
Other details : Upgrading from Mac. I will be using Windows 10 from now on.
I will be using 2 monitors but only 1 for now. Keyboard and a mouse is not a problem.
The budget is for everything except for: Monitor, keyboard, mouse. I also have 1 external storage, 1tb.
Help will be appreciated. Thank you.
https://linustechtips.com/topic/1198713-pc-build-please-help/
Just now, tank234 said:
that psu is a bit overkill
that case has bad airflow
you wont need liquid cooler for that cpu, oyu can get cheaper aricooler
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1198713-pc-build-please-help/#findComment-13634167
15 minutes ago, SavageNeo said:
Hey, thank you for your time. Could you please explain to me why you have chosen those parts? Also is this build hassle free? As in, build it > update it > use it?
https://linustechtips.com/topic/1198713-pc-build-please-help/#findComment-13634185
