I bought a new gpu Asus gtx 750 ti which at start worked perfectly with a 6pin to sata connector but then after a few days it would just during gameplay it would just start showing a screen saying no input display and when i restarted my pc after 2-3hrs it would start working again but it became even worse yesterday i was playing fortnite when suddenly my pc froze and the screen glitched out i tried to restart  my pc but no luck and then i waited till today but it still not working.It works perfectlyfine in safe mode and also when i delete its drivers but when i install its drivers it just reaches the windows logo and then a black screen appears and sometimes the same no display screen appears
My specs are
Core i5 3330
Asus gtx 750 ti oc edition
Hp compaq mt 6005
8 gb ddr3 ram
500gb hdd
I rlly dont know about the motherboard  all i know is that its the default  mobo that comes with the hp compaq mt 6005
And also the pc works perfectly fine with the integrated  graphics it only stops when i install the gpu
https://linustechtips.com/topic/1198318-pls-i-need-help/
new as in brand new? ?
it's been a long time since 700 series were discontinued. if it was labelled "brand new" i doubt it actually is. not impossible, but, just, like... new? really?
if you bought it 2nd hand then i wouldn't be surprised if there's something wrong with the card itself.
Please give kudos if you find someone's reply helpful 😃
In case you wonder about my forum name, it's either Cthulhu or two dwarves about to make out ;)
Now that you've seen it, can you unsee it?
Get motion sickness playing FPS =(
"You so ugly you scaring away the fish!"
>>> "BOOB JOB" <<<
Ryzen 3600
MSI B450m Mortar Max
2 x Corsair low clearance DDR4 8G 3200MHz C16
GeForce GTX 780 Ti (temporarily downgraded)
Silverstone FT03
Samsung EVO 2.5" SSD 500G (boot) + WD SN550 1TB (game lib)
WD Elements 3.5" HDD 1.5T (storage; pulled from an old external drive)
Seasonic SS-660XPII 660W 80Plus Platinum Ver II
DeepCool Gammaxx GT (CPU)
Silverstone AB120R (intake)
2 x Silverstone AP81 (intake)
Silversrone FN121-P (exhaust)
AG AGON AG323QCXE (What a hidden gem)
NiZ Plum Electro-capacitive Keyboard
Logitech G703 Hero Lightspeed
Koss Sporta
Windows 10 Pro
Linksys WRT1900ACS (rocking OpenWrt)
WD Elements 5T external HDD (network backup drive)
https://linustechtips.com/topic/1198318-pls-i-need-help/#findComment-13631238
Is there such a thing as a new 750ti?  That’s an old card.  Recently purchased used perhaps.
https://linustechtips.com/topic/1198318-pls-i-need-help/#findComment-13631260
