I am building my first pc this year and just needed some help on choosing between cpus. I know I want Ryzen but not sure which one to get for a single gaming/streaming set up. I was looking at the 3700x 3900x and 3950x but not sure which to get. I want good fps with still holding the ability to stream at a high quality and not drop frames.
https://linustechtips.com/topic/1198174-cpu-help/
depends on your budget. all of them are perfect for streaming
If you can get the 3900x why not? idk how much better then 3950x is or the cost difference. but the 3700x I have and when streaming red dead 2 my CPU usage is still very low.
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/1198174-cpu-help/#findComment-13629955
2 minutes ago, xStorm33 said:
got a big budget 3500 but still not sure what to get cause all I play is cod and rainbow while I stream so idk which one will do the best for me
country and currency? i can help you build a streaming/ gmaing pc
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1198174-cpu-help/#findComment-13629978
4 minutes ago, xStorm33 said:
so whats the best to get?
Damn, 3500 is a helluva budget for a first PC. Go for a 2080ti and a 3950x.
Case: InWin 303 Motherboard: Asus TUF X570-Plus Processor: Ryzen R9-3900x GPU: Gigabyte RTX 3070 Ram: 32 GB DDR4 3000 MHZ
 PSU: Corsair CX750M Storage: 1TB Intel 660p NVME SSD and a 2TB Seagate 7200RPM HDD Mouse: Logitech G600 Keyboard: Razer Blackwidow Ultimate 2014 HeadphonesSteelseries Arctis 7 Audio: Shure PGA58 with a Focusrite Scarlett Solo 3rd Gen
https://linustechtips.com/topic/1198174-cpu-help/#findComment-13630021
3600 is enough. hell, even 3300x is enough as demonstrated by a big tech youtuber. these should be your bottom line and then just go from there.
also, if you can, wait for next gen ryzen.
all the more important is that get nvidia gpu which has better hardware video encoder.
Please give kudos if you find someone's reply helpful 😃
In case you wonder about my forum name, it's either Cthulhu or two dwarves about to make out ;)
Now that you've seen it, can you unsee it?
Get motion sickness playing FPS =(
"You so ugly you scaring away the fish!"
>>> "BOOB JOB" <<<
Ryzen 3600
MSI B450m Mortar Max
2 x Corsair low clearance DDR4 8G 3200MHz C16
GeForce GTX 780 Ti (temporarily downgraded)
Silverstone FT03
Samsung EVO 2.5" SSD 500G (boot) + WD SN550 1TB (game lib)
WD Elements 3.5" HDD 1.5T (storage; pulled from an old external drive)
Seasonic SS-660XPII 660W 80Plus Platinum Ver II
DeepCool Gammaxx GT (CPU)
Silverstone AB120R (intake)
2 x Silverstone AP81 (intake)
Silversrone FN121-P (exhaust)
AG AGON AG323QCXE (What a hidden gem)
NiZ Plum Electro-capacitive Keyboard
Logitech G703 Hero Lightspeed
Koss Sporta
Windows 10 Pro
Linksys WRT1900ACS (rocking OpenWrt)
WD Elements 5T external HDD (network backup drive)
https://linustechtips.com/topic/1198174-cpu-help/#findComment-13630029
 This has $400 left over for peripherals or RGB. I included 2 monitors, as I wasn’t sure wether you needed them, but the 165hz is for the game and the 60hz for chat/obs.
id recommend waiting for ryzen 4th gen and ampere GPUs later this year tho.
https://linustechtips.com/topic/1198174-cpu-help/#findComment-13630062
https://linustechtips.com/topic/1198174-cpu-help/#findComment-13630214
59 minutes ago, xStorm33 said:
Watercooler isn't needed, a esports duo 34 would be fine. You have 64GB of RAM, max you would need is 32GB. Corsair Fans arent that good, go for Noctua Ones and if you want RGB, put on Phanteks Halo RIngs. 850w is overkill, but if it's like $10 more then get it.
In short:
 You still have $300 dollars for sleeved extensions, the RGB rings for the fans etc.
If possible, wait until later this year when Ryzen 4th gen and the new nvidia Ampere GPUs launch.
https://linustechtips.com/topic/1198174-cpu-help/#findComment-13630365
